screen shots arent loading?
Pathamilton now invades all of ozhonda with his pics of girls. Love/date stories and his profiles on online sites. And lots of screenshots from tinder. Lmao
Lmao. Prolly cause theres no mods on ozhonda.
Nah I mean hes got a whole thread dedicated to posting screenshots of chicks profiles that he thinks he got chance with.
Hoonchans house of love is a good read.
And the asian girls thread is filled with his level 1 yellow fever. And questionable underage photos. And them sneaky photos fron public
Posted Image
Parma and burger joint in cbd recommendation.
Kgo!
Parma = any pub you see. Cause its a bloody parma
Burger:
Mr burger on little bourke (I think) get the mr meat.
Huxtaburger on smith st in collingwood. But I think theres a huxtaburger in cbd somewhere
Bought the GoPro at JB Hifi... Marked Price was the RRP Price of $529...
I asked if they can do any better than that, because a bunch of other places are selling them for $449, or even $480 for brick and mortar stores.
He said "I can't do anything under $513 which is Cost price for JB Hifi"
He didn't have an answer when I said "Seriously? Why are you selling them at all if you're only making $17 from a sale of the High End model?"
Bought it anyway. Sick of fking around trying to get one in my hands before next weekend.
dont you already have one si?
I have a Hero HD2... This is the Hero HD3+ Black, 2 versions newer and a lot of improvements. Will sell the HD2 off at some point in the future.
At your rate prob make half your money back by renting it when people borrow it :woot:
50 bucks and a coles chicken.
COOKED!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
