2 weeks... what else is there that's drawing power? you could test the current draw of the alarm / car with everything turned off
Since the battery has been dead before, it might have lessened capacity now... do you have a proper 3+ Stage Mains Plug-In Charger? Alternatively, you could buy one of those little solar panels which tickle charges when the car isn't running to keep it topped up :) Worked great for my dads old boat when we didn't go near it for a few months at a time.
yeah wil do current check when I get it back.
charger is 6 stage I think. will get battery checked this week, it's an odyssey just over a year old and I think it might be stuffed. farkin hope the alternator or start motor isn't killing it.
Anyone here have a spare coolant bottle cap? Mine went missing.... :/
For a temp fix, try a plastic milk bottle cap, they're about the same size... little bit of electrical tape around the neck if it's a touch too big...
It doesn't hold pressure or anything since there's the overflow port next to it, so its just to stop it from sloshing about into your engine bay while cornering :P
There's two of the chinese places at knox city. I've been to one which isn't bad, it's in the short "Arm" of shops on the lower level, opposite the main food court. They do pants really well, cheap and fast too. And I've had a few dress shirts altered there as well.
Was just going through old pics and found this from back in 2008 or thereabouts. Me and my mate borrowed his older bro's Calais to go for a spin down to St Kilda beach (to try impress ladies, as you do when you're 18 :no: ) and couldn't figure out why the thing was so sluggish. Opened boot to find this:
Not sure if better or worse than cutties :S
LOL. When SSSL's at the rears aren't low enough. :P
if you just need one for the weekend, I imagine the S14 one is same as volvo ones.
borrow mine now I'm out.
Need it back after tho.
Will do Martin!
You're in Yarraville if I remember correctly?
Why you party poop and no deca?
Tried a water bottle cap and it's just a bit small, milk cap seems too big. :-/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
