the leaf situation looked kinda like this Aaron. :P
Quoted for Aaron, but also for the spider's determination. It's quite inspiring that he's still hanging on by one leg.
Where did you get those milk crates from? I'm in need for some...
stole them from petrol stations and the rear of a Safeway.
the trick with the petrol stations is a 2 man operation and to park the car as close to the crates as possible. just be wary that it is illegal lol. gathered 22 in a short morning
LOL had a similar concept...
to build a stage in our backyard for a 21st
^ this, I need a stage too. Great minds do think alike hahaha
Are you still using the crates or needing it?
lets go ride next sunday morning!
need to get brake pads and an 18tooth cog and i'll be good.
Where?
I can probably get you cheap prices but I'm sure you already have connections. I had road tires on so let me know and I'll swap them back to mtb tires
sorry that was like 2-3 years ago. they long gone. look for an abondended Safeway cargo bay with crates and back the stages up :P
It's true... you cant be mad at us for that... they like warm places to lay their eggs in safety
forgot to mention they also like the inside of seats to lay the eggs as it's like their natural nesting places... warm, cosy and nothing can get to their babies... hundreds and hundreds of babies
also:
Doctors find spider that had been living in Chinese woman's ear for FIVE days... after it crawled in while she slept
  • Woman went to doctor complaining of an 'itchy ear'
  • Doctors feared the spider would bite her at any time
Read more: http://www.dailymail.co.uk/news/article-2186522/Womans-itchy-ear-caused-spider-living-FIVE-days.html#ixzz2krO7CL11
also:
while she slept
WHILE SHE SLEPT
Where?
lol. st kilda? we can be hipster and sip coffees and ride.
i dont know trails. gotta ask huy about that.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
