My VL's fuel gauge (and probably everyone else's) used to intermittently stop working. A good slap of the dash would bring it back to life usually. Finally got fed up with that and pulled the cluster out, turned out there were a bunch of cold-soldered joints that had cracked. Re-flowed them and no more worries :yes:
I thought of doing this 12 months ago. storage/security/tools are a bit f an issue unless strict rules are enforced.
car is at tuners for run-in. thing won't idle when warm... suspect AFM has finally carked it :( bought one from a member literally 2 days ago. hope I get it before this weekend...
vic club should hire one. we all chip in 10 bucks a week, or 20. we have lift installed, and we all have to book in to use the workshop.
I'd want to keep my car there as well, since I don't have a garage :D
Huge liability issues right there, I doubt SAU Vic would wanna get involved in that without some exxy insurance as they could pretty easily get sued...but it isn't a bad idea by any stretch.
Just get a couple of people to chip in for a 1 year lease up front, get address and drivers licence details, install a security camera and away you go!
yea i get ya. but if we leave it empty...... some one would be there every night working anyway haha!
im down for weekly payments. no up front shizzle tho! but only if its got a lift~
Can pick up a 2 post hoist for $3k or so I think...
I know a few blokes who share a garage in an industrial area in a similar way, seems to work for them and it makes their girlfriends happy to not have all the junk in the garage ;)
everyone on the internet is just like "just solder the contacts on the AFM, its a piece of piss" "Z32 AFMs often get bad connections, just open it up and have a look"
no one tells you how to open it or how not to open it. if mine wasnt f**ked, it certainly is now lol
anyone know where i can get one locally even if its a bosch one?
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
