thats a good point!
but i doubt ill need any more power than stock mate-torque steer is a killer.
and the only lsd avail, is a nismo one at about 4 grand.
I got a set of stock R33 GTR turbos (same as R32 GTR)
If you need a spare / backup turbo.
thank man! already have two on the way, one is shot but i can rebuild it in my spare time.
Wow, that's a crazy price difference....
and you guys have tolls, we don't have any of that shit
WA for lyf!
You have working internet in lovely bit of sticks?
Speaking of regos, my rego on my 97 r33 gts-4 n/a runs out in a month, anyone know how much i should be expecting to pay? P plater if that means anything.
Regos seem to me to be same same on the whole... Should be cheaper if you're on concession though
