Duly noted, thank you peeps. And thanks for the butter recipe Ham. Omelettes are badass and their simplicity and low mess make them win at life. My omelettes are so busy I have to use a handful of cheese as a binding agent or it goes Hindenburg on me...
Would love to add vegetables for texture, but I don't want to mess with my all meat tastes. Parsley as a pub meal garnish is as far as I would go!
the humanity
Waxed bonnet, then cbfed the rest of the car so now I have a nice smooth bonnet but nothing else :D
Dat arm / shoulder workout rubbing that bitch off
Edited by UNR33L
Yuck what for?
was driving normally 5th gear doing about 70-75 in a 80 zone coming back home from work literally 2 mins away from home yellow one pops up out of nowhere tailgaits me puts the lights on and shit. Partner was a good bloke but main guy was pretty rude. He warned me for my rear licence plate for being bent and unable to read from a 45 deg angle. Got a fine for driving manual on auto licence (my fault for not booking my test sooner so not complaining left my car at site and walked home) but also for "failing to display p-plate rear" even though it was up and on factory uv cut tint that has passed Rwc he said he couldn't see it and gave me a fine and 3 points....I was on 1 point before this so licence is bye bye unless I contest. :(
I got done for the EXACT same thing.
It would of been 4+ years ago, on my P's in my N/A R33 just when green P's were just introduced.
Pulled over - done for manual with auto license (had the re-test booked but you know vicroads delay and what not, fair enough $150 and my fault) Then also said P plates not displayed cos you couldn't really see them that well through the tint, and with water on the rear window. $150 and 3 points for that as well, I wrote a letter to Vic faggotpolicegayflamin mongrels and got out of the P plate thing. From then had to display them on outside of car with magnetic P plate on the back which were sometimes taken but meh.. got through my Ps eventually.
Then got a 33r off Ps, random EPA etc in the mail and just had enough in general sold up and got a ford, buy a ford. inb4grant
No points at guessing which flamin mongrel pulled me over ;)
Edited by UNR33L
  • Like 1
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
