So plugged ps3 in for first time since GT5 came out.
have 3 games for it, GTA4 GT5 prologue and GT5
load up GT5 goes to do update, not enough room on drive.
None of these are DL all on disc, so seems I can only keep 1-2 games data
no wonder I gave on on gaming.
lucky ahve a spare 1Tb 2.5 drive in house, upgrade time b4 GT6 comes out.
mate i finally got gta5 for xbox...loads up after i wipe the hdd of almost everything...
freezes every half hour or so and wont save....
turns out a common problem on older xboxs so now i need new xbox to play it...
I feel your pain...
the PS3 I ahve was a day 1 release for PS3 mate had one on pre oder then his work gave him another one, (worked for a gaming comapny)
SO he gave this one to me years back but I barely used it. last save game I can find is 2009
SO I today I finally unplugged my original xbox and plugged this in
got a week off over christmas so will give GT6 a try for a few days.
Center muffler @ 6cm, Just a Minor with no Fines or RWC required
Actually came away pretty happy, considering they did inspect the engine bay :rolleyes:
Was the Knox Yellow HWP car, not our special friend though...
isn't yours top mount?
Na, highflowed R34 op6 housing, still on the factory manifold, everything looks stock just no heat shield over the turbo anymore because of the different actuator.
they're getting soft.
Can't even see your intake with the airbok over the top, it's not illegal as far as I know, but anything out of the ordinary is going to make them look further.... It's sprayed a nice satin black anyhow and is in shadow
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
