Anyone got the tips for good food joints in Patong? Been there before but only for 4 days 90% of which was spent getting tattooed.
I want to eat at all these joints people always talk about where they fed their family with lobster for $3 each...
Last time I was there I lived off maccas/HJ's and some chicken from a street market (which was delicious), but keen to get some variety this time as I'll be there for 2 weeks
There was a place I went too that was right on the shoreline, can't remember exactly what it was called but the locals might know, was awesome
was about 10-15min drive from Patong beach iirc, if not eat where the locals eat, also best way not to get sick :P
Any luck with that c63 auction info aaron?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
