what cars are in the 15-20k bracket that fit the following, looking at cheaper options to see if any grab me sufficiently to sway me from the 35k+ evo x
small/medium sized car, dont need a land yacht.
Turbo (minor mods will net ~200kw+)
decent factory options (if they have them and what), cruise, ok stereo, auto wipers/lights etc
fairly new 06+
can be had with fairly low km, 50-80,000km
so far the list is
Ford XR5 (5 cyl volvo engine (do rate), only comes in manual)
Mazda 3 MPS (good engine, bit laggy but makes butt loads of torque, only comes in manual)
WRX (has boxer engine, dont mind the sound, but not sure if i want that sound ALL the time)
Ralliart Lancer (Has DSG ONLY, but from owners of them i have been told the suspension is quite pedestrian as are the brakes)
MK 5 Golf GTi (Has DSG option, almost all have 100-150+ km, not the best of the GTI models, engines are a bit weak if modded much)
fairly new 06+
so far the list is
FWD is for teh gheys....
If after reading this your list has narrowed to 2 options, that is acceptable
If it is narrowed to 3, then GTFO
For that bracket/specifications he'd only have WRX, not STi though... I don't mind the hatch look itself. WRX was gonna be my suggestion, though.
Golfs, would only want an R really but they're more monies... same with the Sirocco (also it's fwd... should have made it awd like the R)... maybe mkv R32 or GTD ?
Thought about any euros besides the golf?
Not sure on prices, and they're probably into large car territory, but fg f6 is pretty powahhh. Or maybe xr6t?
Or you know... Just buy the X :P
MPS certainly doesnt float my boat, even though im FWD biased. Ugly, large, relatively heavy and somewhat complicated engine from what I can gather.
XR5 turbo comes recommended, but I'd go a bit further and go volvo personally. 3" inch straight through, tune and LSD and you're done
whos the biggest wanker here...
the gym wanker with spindles.
the bro curling wanker in the back ground?
no its the phone wanker in the gym. f**k you mate.
closely followed by everyone who ever went to a gym.
Xr6t , don't mind them but it's large and I don't need a car that big.
Haven't looked at other euros, don't want anything horribly expensive to fix though.
2 votes for the wrx hatch
2 votes for the xr5
my vote only counts for WRX if STI - otherwise vote defaults to evo 9 which I added to your list whether you like it or not
from what I understand it's a BP motor, same as the mazda GTR. That being the case it would be pretty to get 200kw from with no issues, and at 1 tonne that's pretty damn fun!
what's the gearbox like though, is it made of glass like the GTR?
Lol why so much hate
Go to the gym, do your thing and go home.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
