I actually miss that car, apparently he blew the engine and there's another in there now been up for sale 3 times now since I sold it
buy back cheap, restore to former glory & rep, sell for profit.
ACA giving Christmas hampers away to people and interviewing them as they go, asking them how tough they have it this Christmas etc.
First woman says she and her husband (who works for Holden, so will lose job in 4 years, boohoo), didn't renew car insurance and he recently had a car accident, so they are doing it tough.
Then they ask some bogan looking guy how much he has in the bank account and he says about 83 cents; says he has 2 kids and a third on the way.
ACA y u no like Darwinian theory
  • Like 1
Another rant if I may.
> In JB HiFi buying computer game
> $80 in store
> Look at JB online price using phone
> $60 online, with pickup available at retail store
> Buy online, walk to counter and collect
Does retail want to fail?
i cant believe that. thats just retarded... i just *blank* brain fail.
beer time, got all boot sound deadening removed. rest now, mcflurry time later.
is this the light holder Miguel was after?
First woman says she and her husband (who works for Holden, so will lose job in 4 years, boohoo), didn't renew car insurance and he recently had a car accident, so they are doing it tough,
if you have all of 83 cents to your name, more children is not what you need.
Remind me of this
fkn too hot today...
my car alarm speaker died.
just started going off at full volume, didn't respond to the remote, open bonnet (loud as an air raid siren in a small concrete room) use the key, still no response.
WILL NOT TURN OFF
so of course I did the only manly thing possible and ripped it out.
once in my had it started popping and cracking. dropped it on the ground and it made a few big explodey type noises.
riiiiiiiiiiiiiiiiiiiiiiiiiiight
so i still have an immobiliser but no sounds :/
Is that a front indicator? Chasing a pair of sides to suit a T2 bulb because bought nismo clear side indicators for daily, figured they'd be fine but A32 indicator socket uses a different offset for the bulb so they hit the lense :/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
