How many litres did you fill it up with? I'm guessing around 50 litres, in which case that's pretty normal economy for a Skyline. And if it hasn't been done, changing the oxygen sensor can help your fuel economy. But I wouldn't be bother if you net around 400km from 50 litres.
A light will come on when the needle is near the E and you'll still have 20km or so left. It's a 60 litre tank.
When i filled it up it was on the 2nd last bar, i filled it up all the way with 100 octane which costed me $65, i think i got around 35 litres before it wouldnt go anymore, it was $1.65 per litre and i put $65 in, so whatever that adds up to is how much i filled it up before it wouldnt go anymore.
My sender is acting funny also.
Haven't bothered to clean it, as long I get at least 400km out of the tank s'all good.
I've managed bit over 500 on a tank before fillin it up today.
Your fuel economy is fine for an N/A 2.5 6 cylinder of that age. If you used 39 litres and got 350km, that's around 11L/100km.
I don't think your fuel sender is terribly inaccurate either. If you assume that half a tank is 30 litres and you were on the next bar, 39 litres isn't a stretch. There's still a good 7-8 litres left after the needle touches the last line.
I wouldn't worry about running out of fuel until your fuel light comes on. It's a bit past the last line on the gauge, just before the needle touches E.
OP6 vs 21U housing - do they share the same bolt pattern and distance from flange to firewall? Thinking of buying a blown 34 turbo to highflow to net an extra ~20hp headroom.
Same bolt pattern, not sure about distance, but it doesn't matter, cause OP6 has been fitted many times without issue. If you're going through HG just give him a 2IU housing and get an SS1PU.
  • Like 1
Might pick up some injectors tonight.
If so, that's pretty much everything for first round of mods! Will just need to install all the parts + tune. Yayerr. :D.
Although still deciding whether I have enough cash moniez to also grab aem afr/boost gauge.
Doesn't the SS1PU push the exhaust back even further, or has Tao fixed that? Have you had any long-term issues with yours?
The SS1PU pushes it back further because it's a new turbine housing, not just a high flow of the stock housing. I've had no clearance issues issues, there was plenty of room for my exhaust...still is. Air con drip hose (?) was slightly touching the dump pipe, but I tied it back and it doesn't contact anymore.
Will do a detailed post in the HG thread later today to kill some myths, as I've seen a bit of garbage posted in there lately.
..Will do a detailed post in the HG thread later today to kill some myths, as I've seen a bit of garbage posted in there lately.
Yeh that would help a lot, there are so many conflicting statements made about that turbo.
Post up your setup+results to go with it
just went to look at a new GTi.
I could not believe how bad the service at the dealer was.
avoided answering questions. fairly simple ones.
ME: when the performance pack is coming out,
THEM: OH GTI's are very popular you will need to put a deposit down to get anything.
ME: what is the lead time if I want XYZ
THEM: Oh you should be happy with any we can offer you as they are very popular.
SO I had looked on their site and they have some optional wheels that I liked more Lighter and wider.
ME: How much are the wheels I saw on the VW site.
THEM, oh I couldn't option them, the normal ones are too popular, you could get them from the spare parts department later if you wanted but we could get you some cheap tyres to put on them!
ME: How much is the sunroof on one
THEM: the GTI is a very good buy as they now have capped priced service.(!!!)
ME oh ok how much is the capped price service
THEM, OH we have not set the price yet but is is sure to ber very cheap. I can tell you the price of the Series6 GTi but it won't be the same.
so frustrating.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
