You can buy duty free from Singapore and bring back to Aus, I brought in 2L of vodka. It's best to buy your alcohol at the stop immediately prior to your final destination as if there's a stop over inbetween you may not be able to board your next flight with it.
Edited by L33SH
A mate just came back through there, claimed he couldn't bring anything as SG --> Aus was not allowed. I was skeptical to say the least
I think it has to go through checked baggage rather than carry on, or vice versa.
Rekin couldn't bring back a 40oz of Absolut which he purchased on his way into Singapore, so he left it with me when he went back. This might have been because he had no checked baggage.
I remember now...you have to take it back as checked baggage, but you can't access duty free shops at Changi until you've checked your baggage...so you have to buy it as you are entering Singapore rather than when you are leaving. And pack it in suitcase/checked.
Fair enough. Guess my mate is absolved then
Thanks brah
Can any brahs confirm if you can/cannot bring in duty free liquor from Singapore
now here a topic I know well..
Singapore is one of the few countries you can still buy duty free and bring it to aust after buying in the airport.
you need to be there early however if you buy last sec they wont sell it to you as they don;t ahve time.
YOU buy the alcohol, and they bag it
give you a ticket.
you then go to the gate, go through security
Go through the LAG check that is a solely AU requirement,
and after the this you give the attendant in the boarding lounge the ticket and you get your bag.
remember you cannot carry on any liquid more than 100 ml onto a flight to AU international
unless they do this check.
HK/Bangkok do not offer this.
Dubai does a variant of this allowing you to buy.
not that I've done this b4.
Melb arrivals Duty free prices...higher than dan murphy's usually.
Customs asked me if I had any pharmaceuticals/steroids disguised as shampoos etc
I said "Nope"
He said ok exit through there
Next time I'm bringing in all the steroids
Should have grilled customs
This is all naturale
Just becuase I look big doesn't mean i take steriods
Do you even lift?
Police Ten Seven; a New Zealand based road patrol reality series.
Ahh gotcha, seen some of there shows!
so of the 3 cars we have here...the race car is the only one who's aircond working properly..
re gas for the other 2 needed me thinks
add in thick as radiator and low temp thermostat...it likes it better than most cars
lol that sounds alright!
im running low temp thermostat also.. still seems when i'm in stop start traffic it can get up to where a normal thermostat will..
then back very low while driving.
bit worried about taking it out now tbh..
Car is off the road at the moment, but I reckon my oil temps would hit 105-110c in this heat in daily commuting
:O more mods?!
:O more mods?!
Never ending
Sticking a 3582 on it. Will be ready this week and in for a tune next week
Then off the road again after that to fix my front bumper then off again after that to fit an oil cooler haha
  • Like 1
Car is running ace in the heat
Because RacePace tune
I was going to get Racepace to tune it if I never got a reply from Chequered
damn tony!
going to be damn fast!
who is doing the tune?
Trent is doing the tune. Booked in for next Wednesday
Anything over 320rwkw Ill be happy with, more so to free up the engine and let it breath in the upper rpm range rather than being chocked up by the small turbo
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
