I need to install a double din head unit, speakers in the front and back, a sub and 2 amps, anyone know anyone/place that installs all that for a good price and does a good job?
I asked jb hifi how much to install all that and they said $650, even i know thats a rip off.
f**k that for a joke. $200 is a metropolitan tow, assuming you even need one once a year lol
applies to every car you drive though, so if you're in a mate's car....
or if you're like me, leaving them headlights on ever so often.....
I agree. Biggest rip. its for people who dont know how to change a flat, jump start or cant stsrt tge car when its flooded. Other than that, its a tow from regional areas.
Also, can use for other cars ONLY if you upgrade cover to a higher level. Which was quite pricey... I got missurs to upgrade for 1 month when we drove to NSW, then downgrade.
You've driven mine, at 270rwkw it only just hangs on to 2nd gear with quality 265 tyres and the 1.5 way. E85 powered turbos come on fast and strong; you'll definitely want those 285s! I'm still very happy with my power for a street car; no desire to upgrade or change it.
That being said, a good right foot controls how much boost you get, so you can always go all out on the tune (within the limits of the clutch) and train that foot. Are you going to have a separate 98 tune or is yours a flex tune?
Gearbox tolerance for power is a piece of string...plenty of people pushing your power levels through these boxes safely; they handle a lot. Others can break the a box with standard power. This is where not so grippy tyres and a soft clutch are your best friends.
This... With 290rwkw @ 1.4ton on 98 I ended up ditching e85 for street duties as it had more than enough.
e85 only for special occasions lol
If only this one wasn't nearly 5k over-priced. Has D1R's with it tho.
http://www.carsales.com.au/private/details/Nissan-Skyline-1998/SSE-AD-2427313/?Cr=19&sdmvc=1
that looks dodgy as, why not even wash a car prior to posting pics for sale? dirty as engine bay, why need 3 air fresheners
plus 13500
ha
  • Like 1
350 minimum.
Yeah went in for a tune on 98, came out of the shop with a e85 tune lol
Yeah might just end up using the 98 map mostly if its too much power for me
your 98 map will be spastic anyway lol
my issue was cruises etc, and that I was using manildra e85 which is only available from one place.
If I go e85 again it'll be united
EOTD they are light cars, and as such 300rwkw is a LOT for street.
they don't actually need 370rwkw just to move them like leigh's cruise liner :P
Yes will be interesting.
On the old turbo i got bored quickly on 280rwkw.
Also an issue with the old turbo on the track was the powerband, sure it came on fullboost at 4,000rpm but then it would run out of puff at 6,000.
New Turbo should give a much wider powerband of 4,500 rpm to 8,000 rpm
Will have to take on leigh from a roll on the new setup once its finished :D
Bitch plz, put me on a hub dyno I'll be making 500rwkw trollface.jpg (nah but srs "430rwkw supra" made less than mine at a certain dyno day.. didn't crack 350 at chasers)
Bring it on! definitely more chance on a roll though that's for sure I've gone my brother a few times from low speed I'm gone by the time he boosts or he just hits boost and wheel spin city cos of the light weight 33 :P even with AD08s it just skates in 2nd sometimes the extra weight helps just squats the car down and grips.
Ofcourse we shall be doing this in a legal environment / on the strip :) but yea I'd imagine you'd have me on roll if dat power is legit
Edited by UNR33L
Gooby pls... I said brake boost.. he'll be on boost before you hit the loud pedal and your taxi just be a dot in his rearview mirror.
Gooby pls, propper 1/4 race from the line :)
My brothers got a GT35something in his, thing don't make boost until 6000rpm!
your brother isn't tony...
4500 - 8000k
you will lose - then be fined for fog lights
face it
Yeah what Hamish said. Im making full boost ~22psi at 4,500 rpm
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
