oh man you'll love it you go the xenons and led's yeah? just leave headlights on auto and jump out at night / jump in at night and the magic will happen as long as you got the feature set to on - should be as standard.
nice i love those rims mines the older model so got the 19" Y arm style was gonna change em over but cbf don't think ill keep it much longer
like this -
yeah has the xenons and leds :D
that does look pretty handy!
yeah those wheels really attracted me compared to alot of others i saw
Euro V8s don't do it for me. Need dat dirty yank, big stroke firing order. All about the idle and the effortless low down, not the high up screams :/
with you 100%
Euro 6's, jap 4's (yes I know you won;t all agree to that) and yank 8's
next major build will be a hemi
so checked out a MB today, holy crap I could not believe the difference in service.
going to hook up a test drive when back from kuwait.
that said boot of a A class smaller than expected.
yeah their service was incredible when I went there also!
Compared to who? Beamer / VW?
As for Jap 4s, Euro 6s and Yank V8s...I'd actually agree with that. Though I think Jap 6s have their own lovely sound up high.
Best 4 cylinder I've heard was a 2T-G in a TA22 GT with Weber 45s. Shit sounded like a miniature big block.
So far the worst was VW.
BMW were ok, when they would eventually talk to us.
mazda were great as well, nissan guy was just sleezy
going to Volvo/ Land rover next
might looka at accord euro as well,
best 4 for me was a race spec BDA escort.
followed by a Datto 1600 with webbers/straight through zorst..
I know a guy at Mb melb if ya want someone good to deal with
Keen to see the gla amg when it comes out
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
