The 33 has neither the motorsport history in Australia of the 32 nor the pop culture fame of the 34 which for a lot of people just means it's not important because there's no hype and because there's no hype it mustn't be good.
The conservative styling certainly doesn't help them stand out either and that coupled with the larger body have earned them dumb boat comments, despite the fact that they're far more composed(like for like) than a 32.
It's good in a way though, it keeps prices down making the 33 exceptionally good value in any variant.
I dont know why anyone would really buy a 32r these days when you consider the 33r value
34s are what still like 40k for a 90s car dafaq?
never seen that cheap... luckiest i found 50k for 90s car -_-
I must say Artz, getting that car for free is a definite score!
attachicon.gifImageUploadedBySAU Community1392071382.088416.jpgattachicon.gifImageUploadedBySAU Community1392071406.053168.jpg
hey thanks for the pics....yeah was a good score...lets not forget the 100hours plus of elbow grease i had to put into to get it in the shape its in...
http://www.carsales.com.au/private/details/Nissan-Skyline-1986/SSE-AD-2621436/?Cr=140&sdmvc=1
This plus an auto pulsar to daily in for less than 10k. Bad idea?
Edited by bucket_boy101
lol @ all the above. including 34R's re-sale being better than every luxury car in the market.
goddamn stuffy and humid out there. can't sleep.
Want me to read you a bed time story to bed?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
