Bullshit. You get change for your notes, it comes in coin form, you carry it home. You're a coin carrier, whether you like it or not.
Thus for all the note only hipsters, a wallet with no coin spot is impotent and futile, as it defeats the point of a wallet in the first place, which is to keep all your shit together in a neat spot. So unless you're going to spontaneously offload your change coins onto some unwilling recipient right then and there, you might as well carry coins and notes and cards all loose in your pocket, or buy shit that adds up to exactly a note, or get a wallet with a f**kin coin spot.
I don't need a cigarette I'm just always pissed off.
i pay for practically everything with a card, but always carry some notes incase they dont accept cards.
Cows are okay, but we need to find another 80ish acres to store them for 6 months until the grass starts growing again, otherwise they have to be sold as there is no feed for them anymore
Been shit though we are stuck at home, all the roads are currently blocked off so if we go into Kilmore or Wallan we can't come back home, even though there is no risk to our place anymore
Power has been off for 2 days straight now too, so running a generator to have at least some power
matter of curiosity how many cows?
They are nice. will be at qantas terminal on friday night, will check out Carry On.
The protective wallet sounds pretty good.
have never paid for a 30c cone on card. but theres a first for everything.
The note sleeve seems to be what I'm after
Paywave brah
In saying that can't say Ive never had 30 cents in the car
dont like Paypass for 2 reasons.
1) takes a few days to process, like a signed transaction. its annoying
2) have been charged twice before because the first scan didnt work, but was processed by my bank i think. got my money back thankfully.
and when will banks make a card where the paint on the numbers dont rub off. FFS its a wallet, not sand paper. stupid cheap cards. millions of dollars on security and can be breached with someone taking the card and paypassing anywhere. and then the card snaps in half in your wallet because off added stress from 50c pieces behind it. stingy dream boats
Flip wallet is perfect carries notes and like 8 cards if you really need that many, without being bulky. I only really carry two credit cards a licence and an atm card which I never even use really.. Plus whatever notes usually sub 100 as I pay everything on credit cards.
And I've never really seen another tradie with a money clip apart from my mate who got one coz he liked mine :)
Forget talking about change in your pocket, how's the car drive Tony? :)
Ha! I took it for a quick spin down some roads the other night
Suprisingly i have lots of traction, full concentration is required tho once you boot it
Best way to describe the car compared to 280rwkw is
2nd gears feels like 1st gear
3rd gear feels like 2nd gear
lol. I think we all know that feeling...
"ehh will give it a bit of juice - oh wait, doing over 100 already, better back off"
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
