If listed all the go fast bits on my car, people would think AMAGAD BUILD THREAD??? but it performs rather.. averagely.
Not bad, just averagely.
It has Tomei type B's in it (engine is 2.8L), adjustable cam gears, and I'm not 100% certain that it's all the way it should be. It probably isn't actually wrong, but I doubt it's completely right so it'll bug me until it's checked.
I've also read many places on SAU that having an adjustable exhaust cam gear is of benefit. So I got one, with my cams, and no one has ever actually adjusted it to see if it does anything. Just a "she'll be right mate its designed to be on +0" in which case why even make the item?
Fair enough, have you had opinions from the tuners etc..?
Is it currently with a reputable workshop?
Curious to know which one its at. PM it if you want to keep the workshop private
bahahahah.
they are race cams for the 1.3 in the micra..... going stupidly cheap. but i dont know enough about duration/lift etc to even contemplate buying them....
I could ask a mate if you REALLY wanted to know....
bahahahah.
race cams for race head or just OEM head???
If OEM will certainly requiring machining. That's about all I know.......and IF I'm wrong well my disclaimer is this.......kiss my French something something dark-side :P
i have consulted the guru of all that is micra.
ghettofrank.
hopefully he should get back to me when he wakes up, but from what im reading your right ants...
this is tomei poncam spec. http://www.rhdjapan.com/tomei-camshafts-procam-poncam-cg13de.html
the engine it came out of must have been mental.
just be wary: procam is for solid lifters. poncam is for hydraulic. anything bigger than 280-290 degrees... you'd want solid.
Dont know much about those engines, but cams that big is like "I need to wait 15mins for my car to warm up before its possible to drive it under 40km/h" and the "my car doesnt make power less than 4krpm"
thanks man. will leave them the f**k alone then.
Seems to be some car enthusiasts on my street, there's been beemers, mercs, and now micra project cars in the carport.
give that micra kent a shout and see if he has any parts!
where you live?
Who needs a daily?
I have a workmate selling a 1995 integra Type R for ~ $2k with RWC
f**k me your kidding?
would have loved that 3 months ago.
prob would still buy if i had sold the clubby.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
