so looked at my car more closely today and realised the roof, bonnet and a little on the passenger side has residue on it too so all in all looks like i'll have to get a full respray. :/
"Chicken 65 hot"
Is indeed quite hot. And a tad dry/old. Signature roti is Rich Maha's only saving grace these days :(
65 shouldn't be that hot... but can easily be dry if overcooked
Had pho at the viet restaurant chain which is popping up.
Such disappoint :(
^ there's ya problem
Full respray at excess insurance cost.
Sounds like a good deal to me!
  • Like 1
this is true haha. :)but have to get coilovers first waiting on import monster to get back to me.
how's the car treating you brah? much fast? horry shiet?
f**ken dream boats. which suburb again?
Yeah she goes allright
Plenty fast
Rowville brah, in the good side of Rowville too :(
What are is the good side of Rowville out of curiosity?
  • Like 1
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
