because he is an aussie bogan of the highest pedigree...
dude listens to fkn Pantera ffs why is this surprising people? lol
Such Ash
http://www.youtube.com/watch?v=X-wESTnggxI
  • Like 1
Good luck
man times have changed haha when i got my old vw done it had a broken passenger mirror and some other stuff got it done for 150 no questions asked a half a year ago now it's hard to find one :/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
