R1R 205/45/16. Yup, 4x100 16x7+33
7" bit skinny for your power innit? :P
R1R is so HNNNNNG in the wet. So so good. Picks up so much shit and flings it in the guard though
Got it through streeter, not very often you see this pop up. Haha, its forged too, around 6kg each.
<3 R1R wet times
Wish they were a bit better in the dry though.
this micra is going to be the little car that can, if you go through with all that you're planning. decked out from top to bottom.
inb4 Thule roof racks with single speed ontop and stance.
Do you have old rims/tyres your going to get rid of?
i hate stance.
im all for filling arches with wheel, but if it aint practical, it aint going near it.
roof rack will help to transport gear to track tho!
spent many hours chatting to scotty last night about the way to go, and he has dragged me kicking and screaming from the ghetto cooler piping i wanted..... ive still got my heart set on a jdm exhaust system or at least rear muffler tho...
Yes, but they're all sold. And most likely cost a lot more than you're looking to spend. Haha
6kg? fuuuaark. 7" is all im running at the moment. anything bigger is scrub-city.
My te37 15x7+35 was around 4kg.. :P
<3 R1R wet times
When they're hot they perform awesome. RSR had better grip than these R1R at cold/warm daily temperatures though (dry). But R1R feels crazy when hot.
Can't wait to hit winton now.
Touche'
I need to get new tyres but figured some of the rims on "JDM rims for sale" you can get a set of rims and semi decent tyres for not much more
See you soon at winton brah
You're spending money on a micra? Can I ask why?
I saw a little toyota starlet the other day at Trent's pushing 190kw, he was going in for an ethanol tune.
There is no way you would expect to get thrashed by a micro car, with a baby on board sticker on the window. I'm all for it. :)
really? :unsure:
my 16x7 +33 is like 8kg without tyres and 14-16kg with.
Pretty sure it was 4kg without tyre.
Touche'
Haha yep. 2nd hand usually better.
When's sau winton day? Going tampered on 10th, I wanna beat my 53, especially when the 53 was my last lap of the day, and the car still had more in it. Gonna have even more in it now due to tyres.
Dezz doesn't like anything.
If dezz was a word in the dictionary, it's meaning would be; "He who hates the world and all it possesses"
maybe Hamish and Dezz should partner up and fight crime or something
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
