How much voltage they're receiving is a huge factor in the flow rate (and I'm sure km's also could be a factor)... Wire it up using a relay to get full voltage instead of 15yo thin wiring designed for a smaller pump and you'll be laughing.
Do I need to run 8GA wire all the way down into the tank for this, or can I use the original wires in the tank and splice on thicker wire outside the tank from battery feed to relay, relay to pump wire. You use the original wiring as the relay trigger yes?
I think I used 6ga...or 5 even...doesnt have to be massive, just thicker than the stock crap....you probably should run it into the tank too..pretty sure I just spilced it in at the top though...doesnt it already have thicker wires In the tank?
This simple mod doubles the fuel.pressure from my tomei pump...hit 6 bar at the gauge. :yes:
hamish plz.
hamish that clutch.
my rajab..
oh my rajab
wow.
freaking nice eh!
personally I prefer a cheaper, nastier clutch as i'm just so used to it now... but still
Oh hai... Was on my way to the SAUVIC AGM, which was only 10 minutes from here.... or 1 minute if I had turned left instead of right at this intersection.
Oops, didn't realise it was on, or so close to work. You can't be far from here then either
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
