How much voltage they're receiving is a huge factor in the flow rate (and I'm sure km's also could be a factor)... Wire it up using a relay to get full voltage instead of 15yo thin wiring designed for a smaller pump and you'll be laughing.
Do I need to run 8GA wire all the way down into the tank for this, or can I use the original wires in the tank and splice on thicker wire outside the tank from battery feed to relay, relay to pump wire. You use the original wiring as the relay trigger yes?
I think I used 6ga...or 5 even...doesnt have to be massive, just thicker than the stock crap....you probably should run it into the tank too..pretty sure I just spilced it in at the top though...doesnt it already have thicker wires In the tank?
This simple mod doubles the fuel.pressure from my tomei pump...hit 6 bar at the gauge. :yes:
hamish plz.
hamish that clutch.
my rajab..
oh my rajab
wow.
freaking nice eh!
personally I prefer a cheaper, nastier clutch as i'm just so used to it now... but still
Oh hai... Was on my way to the SAUVIC AGM, which was only 10 minutes from here.... or 1 minute if I had turned left instead of right at this intersection.
Oops, didn't realise it was on, or so close to work. You can't be far from here then either
    • I used to have Walbro 255's when they were a pretty common update. (or were they 044? 040?) In any case I had a dirty tank. I thought the tank was good, but I would find the filter would clog in maybe ~50km of driving. If the issue persists, well, your fuel system or tank has crap in it that the pump is sucking up.
    • Hi. Ok thanks for the info. I/we do not know what tune is on that Nistune ECU so it is why there is stock ECU and that Nistune is for later when the car is done. I have guy who tunes Nistune and other ECU so i will then take it to him to see and properly tune for the car   And for the update. On 99,9% it is bad fuel pump. Which is wierd cuz it is like 2 years old(brand new walbro 255) and that filter (also brand new) was dirty.  I was alwaya pumped premium(100) on very good petrol station so i dont know how is that possible...
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
