Anyone watch the new series of Survivor?
I haven't really watched any in the last few years but watched the opening one for last night
And there were some Hnnngghhh moments
Will watch again
Added it to my list of shows which auto-download... Shall watch over the weekend sometime... Brawn vs Brains vs Beauty... should be some decent lols at least if they've got some really dense muscle heads and some hotties for eye candy. Then all the challenges are math based puzzles :P
You'd be surprised who loses. Its an interesting match up. Though i wouldn't say its a true "Brains brawns and beauty"
I saw some gifs floating around from last nights show
I wont post it up as its sort of NSFW
But when you watch it you'll know which individual it mainly centres around :P
inb4 SIMON does this
Does he also look through and delete all the staff pron saved on employee computers?
Doubt he delete stuff, probably transferred into his USB for 'future reference' :P
Well lets just say we have quite a few mac's in the office, and they come preinstalled with Photobooth... and when I'm asked to transfer a pretty young thing's account to a new computer, and make sure all her documents, emails and PICTURES are there... Well... they were.
And obviously there's always random questionable content in Downloads folders.
People not realising that every photo that gets taken on their phone gets sync'd to their iPhoto if they've got iCloud turned on, so they do something which opens iPhoto and boom... wife pics from the phone and much awkward silence...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
