Started Uni again today.
I.e. I have a free day :D. But much errands to run, gyms to go, work at night.
Should have just slept in, kept my eyes closed, and pretended I had nothing to do.
http://www.skylinesaustralia.com/forums/topic/438608-federal-rsr-specials/#entry7188048
man, $160-170 each for RSRs is hard to pass-up. might get them on the Super Turismos once the RE002s run out.
should really get decent semis for the TE37s since theyll be shagged by the end of saturday. thinking Kuhmo V70As because of possible sizes.
bitch please, anything bigger than 215 wide is scrub city for me and trying to find track tyres for 16s rules out most manufacterereres.
Yeah my fronts scrub when I hit bumps, getting a bit annoying now a year on lol
When ever someone new gets into the car I have to tell em don't worry about it
Not looking forward to replacing rear tyres, dem $$$ :(
what size fronts you running?
EOI: anyone free wednesday midday/afternoon? need taxi in pulsar to sunshine
Got tune booked in with Cihan but just found out need to get podiatry stuff done in the morning which means local anesthetic in right foot/toe :wacko: not sure if im gonna be able to drive.
Will make it worth while.
How the hell did you get on to him? Hard man to pin down these days.
At least the tune should be good. I would offer to help but I have the kids to look after. :/
s'all good, thanks anyway.
Sent him an email, no reply, sent another email with a bit more urgency and was ready to pull the pin if hadnt heard from him by today. thankfully he replied on saturday.
Does he mind people hanging around during tuning? i dont know if i be bummed catching train from sunshine to clayton.
He usually likes having the customer there, just incase something goes wrong, or he needs to discuss something. Other times he is too busy and wants the car left for a few days.
Stuffed if I would be catching a train home from there. lol.
You'll be right, you were able to blow $60k on a falcon in the first place, surely you can afford these tyres.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
