good vid. looked like gtr_jet there, and that NXR was at Sandown in december. he ran into issues but looks like its running again.
Thats a Milano pulsar. Pretty sure it was an X1 which is AWD but they cant be registered because motor was never put on the compliance list or whatever. PGA guy has one and tracked once with me at Winton... till this happened: (cant add image for some reason)
ran a 12.6 1/4 mile before that though
good ol' CAs. and also why you should use ARP studs.
Both Jason and I ran at Calder that night. Jason popped his gearbox at Sandown but has since put another one in resulting in him running a best of 12.8 I think it was.
The best I could manage was a 12.6 but I could only net 110mph so something was wrong.
Had to get towed home after the Great Ocean Road cruise Saturday as the car started to run like crap. Got home and one of the bolts was missing out of my front turbo outlet so I guess that answers most of my issues.
wait... so you got towed home from the GOR on saturday because your car wasn't running, you get home and notice missing bolts... then take it drag racing 4 days later without repairing it?
She bought you a shot once lol. I remember his long haired ass getting us into the St Kilda location a couple of times, so can't completely hate on him either.
When the blonde bitch running door at La Di Da charged me a cover is when I stopped going. May return to the heart one day...
Do it fgt
Drags was before GOR cruise
OH&S lecture. Dragging on... and on... and on... and on... and on... and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on... and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on... and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on..
and yet can be summed up with 3 words:
Use common Sense.
if you don't have common sense the darwin award is there for a reason..and try not to bread prior to being awarded it.
Use common Sense.
Ditto.
strong unaware of melbourne Grand Prix. queen st is farged. pulsar was sooo close to overheating and of course, there is nowhere to pull over. lucky.
stopped at Andrews Hamburgers in south melbourne for lunch. VWLHC
Pulsar needs more air flow to keep cool? You running thermos? Or just need a better rad?
Rad is fine, was worried thermos eerent coming on but pulled over and they were running. Hsvent been in suvh heavy traffic with it for so long before. 110 water temp on hand controller, never been that high before. Will see how temps go on saturday.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
