mm. sounds easy!
I've never played golf cos I've no desire to play unless I get to drive golf cart.
My brothers know this and they don't ask me to play for that very reason...
Hey Alvin, I went back to Burwood one the other day to check out how the random GTR owner was washing his car. Turns out there's a car wash in the underground carpark, and he was using their water after hours, lol.
So basketball games are pretty awesome to watch, soo much off court entertainment and shit going on when they're not playing will have to see another before I leave here :D did you know they play all kinds of random music and shit to put the opposition off? Lol some guy Mario gets the ball and Mario bros song comes on /themoreyouknow
Also Miley-oke (karaoke) at half time provided many lols
Aus could learn a few things for their sports stuff.
Anyway brahs checking out of miami, bitch.
Edited by UNR33L
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
