Lol they look similar to the BBS RG-R's you sold me :P
Hahaha yep, regretted selling the BBS wheels since that day. This was the next best thing I could do haha
shiieeet. hope you got air suspension in there.
Not sure if serious orrrrrr....... :P
they are 20's????? f**k me. commos just swallow massive rims.....
VE arches are huge
Like the 300C, only 22s will fill them
Was considering 22s but a few things stopped me:
1: 22s with decent offsets don't exist
2: With the bags aired out, the 22s would foul on everything, including bumper brackets
3: 22s make the VE look like a matchbox car. TBH 21" would be the perfect size, but they hardly exist lol
  • Like 1
20s are fine and much more practical; was speaking strictly in terms of filling guards if it was the desired effect.
was serious haha. question answered.
Oops, sorry bud! I talk that much shit about them that I thought everybody knew hahaha :cheers:
All good mate. Yeah, 22s would defiently fill the guards out better from a side-on profile view, but angle the camerea to 3/4 rear or 3/4 front view and it becomes obvious they tuck way too much and don't fill out the guards properly. Had my time with tucking and wanted something different so tried to get the guards filled out witha bit of "flushness" (dirty word haha)
Edited by turbodragon
Not rare, I do see them pop up every now and then.
I believe Import Monster have a set in 18x10 at the moment.
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
