Lol they look similar to the BBS RG-R's you sold me :P
Hahaha yep, regretted selling the BBS wheels since that day. This was the next best thing I could do haha
shiieeet. hope you got air suspension in there.
Not sure if serious orrrrrr....... :P
they are 20's????? f**k me. commos just swallow massive rims.....
VE arches are huge
Like the 300C, only 22s will fill them
Was considering 22s but a few things stopped me:
1: 22s with decent offsets don't exist
2: With the bags aired out, the 22s would foul on everything, including bumper brackets
3: 22s make the VE look like a matchbox car. TBH 21" would be the perfect size, but they hardly exist lol
  • Like 1
20s are fine and much more practical; was speaking strictly in terms of filling guards if it was the desired effect.
was serious haha. question answered.
Oops, sorry bud! I talk that much shit about them that I thought everybody knew hahaha :cheers:
All good mate. Yeah, 22s would defiently fill the guards out better from a side-on profile view, but angle the camerea to 3/4 rear or 3/4 front view and it becomes obvious they tuck way too much and don't fill out the guards properly. Had my time with tucking and wanted something different so tried to get the guards filled out witha bit of "flushness" (dirty word haha)
Edited by turbodragon
Not rare, I do see them pop up every now and then.
I believe Import Monster have a set in 18x10 at the moment.
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
