ahk... cause i googled and this came up: http://www.supercheapauto.com.au/online-store/products/Chemtech-CT14-Degreaser-1-Litre.aspx?pid=10389#@cross
its just a degreaser. Im trying to get an insane amount of dead bugs off the hilux, and also try to get the black rubber/tarmac marks on the side of the pulsar.
Sorry ct18 is the truckwash...ct14 is a degreaser but still oo to use on most things....it would dry out rubbers and things though but good for removing soot and grime buildup...ct20 is a wash and wax....all are pretty good products
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
