yes, it was behind me... while I was at the lights waiting to turn right...
he got sick of waiting and decided to go straight....
amazing to hear and see sooo much metal move so fast
Thanks, will probably give the Glenmorangie a try. Best way of drinking it? On the rocks?
With your mouth usually works best
Incorrect.
They EARN more money than most people in there, then spend it on a maloo, a jetski, a dirt bike, piss and hookers and then leave the mines with nothing to show for their wasted years :P
Nothing to show apart from the $80k+ car, the $20k+ jet ski, $10k dirt bike and a good time....
And they won't care, because they can afford it all without having to finance any of it...
pretty much, although you'd be surprised how often they finance it anyway lol
Ideally you would work FIFO, be a tight ass and not spend your weekends drinking overpriced piss, living cheaply in Perth without impulse buying shit you don't need including koi tats / brand new air con compressors, and saving up for a few years before moving back to civilization and work another career path, post-mining boom, with a comfortable nest egg.
Ideally...
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
