I had the pleasure of meeting Pettit last night. He followed me down Dorset Rd for a bit, then flashed me as I was about to turn off for my friend's house. He and his partner checked out my pod filter, made some jibe about it "sucking in hotter air than normal", then he peered down around my front wheels and the partner said to Pettit that I "was borderline" - I guessed for ride height. Then they let me go. Had they breathalised me they may have got a reading, as around 2 hours prior I had had a single beer. If they did, I reckon they'd have put me through the ringer. And just taken my license on the spot.
Yep, us p platers are treated as if were criminals. Way too many strict rules i dont agree with, some i do though. Im not entirely sure why they are stricter then ever, from what i can see, they went into operation hunt p platers in late 2007-2008. You can see from vids on youtube, its the people who are now in there 30s that made the cops stricter then ever. Hooning was at an all time high around then, from what ive seen in news reports, vids etc, it was so bad they had to introduce these strict rules. Still i never really trust the media, mostly propaganda. According to the media and police, it was the people who are now in there 30s, who screwed this current generation. Thanks!
As a p plater you only start off with 5 points. Your points come back every 3 years if you lose some. You get your full license after being on your p's for 4 years. So what this means is, for 3 years you must not lose your 5 points otherwise youll get your license suspended and youll be reset back to red p's, meaning youll have be on your p plates for 4 years again. Imagine only having 5 points for 3 years. If you cop 2 fines there goes your license. And as you can see, there are all sorts of stupid fines that take away points that shouldnt, example being not displaying p plates = 3 points.
You know what really annoys me the most about this though? Im doing 59 in a 60 zone or 79 in a 80 zone for example. People on there full license do about 5km or so over the limit when theres no police around. Sometimes youll get the jackass who decides to beep because doing the speed limit is too slow for him/her. These people need to realise, we only got 5 points, im not going to cop a 3 point fine for speeding because you want to get home quicker. My dad even admits most people on there full license will get away with going a few km over the speed limit, p plater does it though, end up on a current affair probably. I even asked a cop once why this is the case, hes answer was so we dont end up like the current drivers on the road.
LOL what a load of shit...
Honestly what you've just said there is pretty much a total load of rubbish.
It's all still happening, was and will.
It was nothing to do with people, it was governments just securing the minority group vote due to sensationalist journalism creating a 'increasing problem' of 'hoons' when really nothing had changed... The news outlets were just capitalising on something that was obviously gaining them audience that would listen... Politics kicks in and the fat knees all jerk.
Hell the most senior of Police I've argued with, and had them unable to respond.
They lack the most BASIC concept of what might help to fix the problem and are just focussed on nothing more than a purely reactive type of behaviour.
That's where the problem is coming from.
here here!
Gw2, Ima break it down for you reeeal simple like.
P Platers are inexperienced, shit drivers. PERIOD.
This is why you have less points and this is why you get looked at harder by the police.
There is no conspiracy, you just all suck and will continue to suck until you have a few years experience behind you.
This is fact.
I lost my licence 4 times when I was on p's for a total of 19 months, generally for speeding and haven't lost it once since being on full's as I guess I learnt my lesson.
Moral of the story is keep your car legal and don't drive like a dick.
I did get pulled over in the GTR for the 1st time the other day however. He said he just wanted to check to see if my club reg was legit and tried to tell me my car wasn't old enough. Then I went home.
Ah k. Disc issues will definitely do that, exacerbated by any form issues too. Should speak to Dan in the gym section...he has similar issues with discs I think and has found ways around them. If you ever want me to take a look at your form I can always do that :)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
