Well an officer of the law told us when p platers get there points reset. He said to us every 3 years, you'd think a police officer would know these kinds of things.
It is a load of shit to be honest. First we went to the police telling them it was hes friend who did it. The police said sorry you have to go to vicroads we cant help you. So i drove him to vicroads, they said they cant help him, they gave him the number to the department that controls fines and all that, i forgot the name of it. He called them and they said the only way to get the fine to your friend is to prove he did it, only way to do that is to get him to appear in court and sign a paper admitting he was the one driving the car. He reckons he lost the paper but im not even sure if hes friend was even going to sign, if hes friend did sign he was going to lose hes license and pay a massive fine.
Why would they know?
Victoria Police are NOT responsible for the Demerit Point system. That is VicRoads responsibility... The penalties the Vic Police apply are pre-described so they are just following instruction essentially.
The declaration, on the back of the fine, just fill that out and then it's not your friends problem anymore. It clearly stipulates that on the form.
I think it's just a case of you don't know what you are talking about. I don't mean that in a bad way, just that all the information is out there and you just aren't taking any notice of it.
Someone keyed my bonnet while the car was sitting just in my sister's driveway tonight. Probably some drunk lowlifes at the party next door. On the upside, now I have more motivation to fix the paint chips in the bonnet. :(
Insurance?
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
