is checking fuel pressure the best way to test if a walborough pump is working properly? or just safer to replace the whole thing?
Also chatting to previous owner last night (who is cautious, but also talks some absolute shit) and raised concerns about E85 on old fuel lines and seal (I have seen a document warning cars pre-2004 to steer clear of any ethanol blend because it eat through certian rubbers over time). He also mentioned E85 water/fuel separation if left stagnant in the tank for long periods of time... comments?
Please E85 propaganda experts, you're my only hope.
Fuel pressure combined with flow rate...
You can have a pump which can build up to 45psi over 2 seconds, and then a bung pump which can build up to 45psi over 10 seconds due to low flow rate... Only one of these is going to be able to keep up under high boost situations, do SR20's have a rising rate FPR?
We even for last night lol. But know you owe me twenty for actuator. But I owe you for muffler.
Where does it end!
Huh?
Why do I owe you for the actuator again?
I work on car for free then? Oh okay.
Hey everybody free repairs farken.
Im joking. I got one jd
This is not enough to cover an angry ass pregnant wife that thinks I'm having an a fair with scotty.
LOL @ an affair.
In that case... A slab of ze german beer.
Most of those documents regarding ethanol and old fuel lines are propaganda written by companies with a vested interested in keeping motorists using normal petrols or distributors being overly safe for liability reasons...
And we may spout pro-E85 propaganda, and then it becomes he says she says...
But the difference is, that the pro-E85 people actually have thousands of running vehicles from the early 90s to prove it's not an issue. Now show me all those explosions and fires and clapped out fuel systems from using E85 on pre-2004 vehicles :rofl:
E85 for 6 months and counting!
St Johns First Aid training course tomorrow
Sitting in a classroom with a bunch of other idiots all day... meh, still better than work.
Just remembered I need to memorise a 47 page pdf of pre-reading info before I get there, blergh.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
