deposits wont be sugar.
They are very likely a residue from soluble organic junk in your tank. Kept petrol for awhile? Some gunk settles at the bottom, i expect its the same for e85, except e85 dissolves that shit, and drops them when it evaporates completely.
If your bored on the weekend come around!
Otherwise was going to buy a solder on the weekend and fix my front indicator light, as the wiring as torn off
I'm working Saturday, but free that evening or Sunday morning?
I tried these first:
Narva plus 120
but only lasted about 3 months, moved to phillips, getting at least a year out of these.
No good. Didn't touch the bulb glass during installation, did you? Should have written them an email...they generally send out replacements when that happens in such a short time.
Obviously performance globes differ in life to standard globes but should be getting more than 3 months out of them.
hmmm I'll have get a stand... maybe a sponge would be good too for cleaning the tip (that's what she didn't say, cause she likes it dirty)
also should have lobster roll this weekend. good shit
nah use rubber gloves when handling them to be sure.
didn't want them again if die quick as you have to dismantel parts of the engine bay to replace, (either the whole airbox or the battery and cradle)
so changed up to phillips.
hey if i plod around in 2nd gear and low speed the car is quiet jerky
not beef jerky, but kinda engine revving jerky, almost makes me look like i cant drive
is that the mega cams doing that?? is it something i can tune out with more or less ign timing?
only happens on light cruise in 2nd gear at low speed, if i open the throttle it goes away
My car does this. Wasnt sure if cams or just setup. 3 different tuners and still does it, so not sure if tune will help
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
