which airline?
Virgin
I rate over Qantas, especially the entertainment system...though Qantas had scrambled eggs and hash browns for breakfast on one flight, and that's a win.
Unrelated, boss's sister is a flight attendant with Qantas and apparently airline staff hate FIFOs #@Rekin cause they just keep asking for more beer and treating them like shit...
  • Like 1
yeah each airline has pros and cons.
I used to fly virgin, but were never on time, 2 years straight of flyign every 2 weeks to syd and never arrive on time.
when I changed roles to a customer facing one and had to be on time moved to qantas they more keen to put the pedal down if running late.
most of my friends who are serious flyers paying for it themselves are on virgin however, (easier to get status if nothing else)
but if you flying Intl often,and can get status..qantas is def your friend.
Can be better than business class stuck in their individual seats :)
Though you would have needed some leg fold surely
Captain just said 40 on this A330 including business class bahahah
Only someone who hasn't been in business class would say that.
Burn
Virgin
So employee is annoyed because they have to do their job and not talk shit with their mates? Not like the beer comes from their pocket.
Difference with frequent flyers is that there is no longer a guilt asking for something when in actual fact it's their job to serve.
Usually happens due to running lean at idle as I found out last night, then again today with Greg's car. ;)Cams would make it much more pronounced.
You got widebands fitted guys? Why the hell not?
Interesting.
That's actually the last piece of the puzzle I need to obtain before I put all my mods in.
If anything I'm probably a bit rich atm... flames pls.
matter of interest what the difference between say me and the stereotype FIFO?
You don't seem like a bogan Neanderthal so could be that
Obviously not allll FIFO are bad but it's likely an 80/20 scenario
Just cos it's someone's job to 'serve' does not make them a slave and common courtesy should always apply
  • Like 3
Employee annoyed cos FIFO bogans hitting on attendants, talking rudely to em and treating them like slaves. There to serve, but a bit of manners goes a long way.
As Al said, not all FIFO gonna do it, but you can imagine some of the guys on flights and in business class or the lounges compared to the other clientele who frequent these spots.,,
  • Like 1
Just bought a Wii U.
What is exams? What is money?
More like what is nintendo doing?
Dont mean to hate but the concept of that console is just so bizarre and makes no sense. You could throw all the IPs in the world at it and every game would feel like some iOS spin-off of the actual game. How you finding the tablet?
Nintendo survived as they are virtually unchallenged in their target market.
When sony and microsoft entered the gaming world, rather than try to be the 3rd option, Nintendo re-doubled their efforts with kids games and came up trumps.
No he didn't, you just got butthurt cos he was talkin smack about your scumbag bogan tradie brothers
lol @ your cheap shot, i'll bite anyways.
two points were made by Birds in his original response;
1. Serving a lot of beer - Its not coming out of their pockets & its part of their job requirement to serve, so how is that an issue? (Unless all they want to do is have an easy ride/shift)
2. Treating them rude - no disagrement here, not acceptable at any time.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
