read that a while back....
Asking for cooked sushi at Sukiyabashi Jiro
i wonder how she even got a booking? like you cant walk in... you would know of the place before you book.
like it is seriously HARD to get a table there... shit take major effort
I see what you may or may not have meant to do there
  • Like 2
Talk of writing car off 2 days after lovely result
Sadness
Desire to do it and buy http://www.skylinesaustralia.com/forums/topic/439783-r33-gtr-vspec-forged-engine/?hl=gtr#entry7289108 extremely high
especially as its Victoria proof
dilemma+
Sadness
dilemma+
negative. buy mint looking 4 door 33 on drift sales for 3 grand. drop your engine and shit in it. profit!
Sadness
dilemma+
yeah thought they might...its a bad corner to hit, not easily repaired...just buy back from insurance company and profit...
Sadness
dilemma+
Go buy the GTR
Then tell us what it's like once you are inside the inner sanctum of the GTR/Melbourne GTR/R33 GTR owners club!
  • Like 1
Yeah.. there's many options on the table.. some are 'easier' than others.
It's going on a hoist at Micolour today. Will have to physically have a look under there and see just how destroyed it all actually is.
The whole write off, buy back wreck is an option too, lots of messing around though.
Engine swaps are not always that simple either.
Only thing more Victoria proof than a boring auto R34 sedan, is something that is actually EPA proof
but.. 330kw @ 3500..
hmmmmmhmhmhmmmmhmhmhrrrrmmhmrmhmmaremarmamfgdFFS
Went through the exact situation as yourself
R34 write off
Buy back off insurance
New engine swap
Was a pretty straight forwardish process
R34 write off
New engine swap
you'd be absolutely insane not too after the money hes poured under the bonnet......
R34 write off
New engine swap
Were you with shannons?
How much did it cost, relative to what the agreed value was?
Some people have suggested this actually ends up 'making' money.
Who did the job?
Did you just do the engine, or the entire driveline, suspension, etc?
Mine is auto, there'd be a lot of wiring and random junk to do to. Most/all of which is undocumented and highly shit.
Pretty sure the assessor wouldn't know what his looking for mods wise so should be a low buy back value
Going to guess about $2k
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
