So yours was pretty much just a new pulley to up the boost a bit and tuning the stock ecu... then a few supporting mods. You had to do injectors as well yeah?
my pulley is still standard, the computer controls a 'wastegate' type valve that bleeds off boost from factory. injectors standard as well, only supporting mods I did was tyres and coilovers lol
If I wanted more boost from where I am at the moment would need a new pulley, but along with more boost would become more heat, needing intercooler as well, and at that power level need injectors as well! This is why I'm happy with 'only' 370rwkw
Barring shitty forced induction setup, I would expect a bit more power given an extra litre of displacement...
not really, the ford heads meant to flow a lot better I think, thats why they make awesome power from just 5.0l (something along those lines) the design of the LS engines pretty old school in comparison - michael the bloke with supercharged XR8 would know more about the differences
Edited by UNR33L
The problem with Leigh's car is that it's too perfectly in it's power delivery...see above. It still feels quick but not as quick as you are going. Your joy needs to come from smashing other cars, getting the tale out or getting to ridiculous speeds quickly.
The G tech picked up greater instantaneous G force in my car, which was a lot slower.
Which is why I say blower for drivability, turbo for fun.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
