Pics of black VE SS utes with decent rims.... considering getting aftermarket rims, or just powder coating the stock 19's black to change it up when I get new treads...
No bigger than 19's though, still need to tow the bike etc with it ..
tell me about it, every time I fly out thow out a fridge full of stuff.
such a waste
or end up eating out instead of buying stuff in also wasting money
I feel your pain brother.
All dat wastage.
Coles offered 2 for 1 pack of cherry tomatoes!! I didn't even get a chance to open the second pack before turfing it.
Damn you society for making everything family size/deals
so I google varreston commodore as there a set I saw on a VE a whiel I actually liked
and what do I get returned
haha
and yeah pretty sure the above same as mine I had 20s on some concave style but back to 19s with phat tyres <3
Edited by UNR33L
This is mad:
10454079_531686560288091_283796237126407
Heres the link anyway to fb group I have liked have a look:
https://www.facebook.com/SlammedHsvsFpvs
it's easy, just find good jap style rims in good offset - throw on holden / ford - then look better than 99.9% of other ones out there
Edited by UNR33L
artworks-000042030583-sysjkt-crop.jpg?30
Yeah, but you think D1R's or whatever they're called, look good..
This is mad:
Yours are 19" in that photo? they look smaller... Would probably look even smaller on my car with the bigger guards...
No point getting ideas off the ones you posted above when they've got massive flared/bolt on guards and slammed within 20mm of the ground.....Won't look anything like that on mine..
Yeh mine are 19s in that pic, the reason they look smaller is because I went up a level of side profile in the tyres for more grip as well.
Prob with 20s as well is makes brakes look tiny.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
