if you want a cool story you should read the comments your mate posts after every status you post, referring ever so slightly to anything
he didn't make survive cull
Did a road trip to Moama, mate was in his Prelude. They have the non memory position diver seats like Skylines...I joked to him at the end of the trip that it'd be funny if I adjusted the seat (he was OCD about his seat's position and hated not being able to get it perfect after someone's fked with it), he took my joke very badly. Gathered Preludes aren't comfortable cruisers.
Oh well, enjoy Ric.
Bunch of slack-jawed faggots around here.
8 hours ain't shit, harden up fellas
Toe kills tyres. Camber just decides where it wears out the tyres first ay.
Centreline will be around $200. TruTrack around $180. Traction Tyres around $120
Cheers guys, didn't think it'll cost that much.
Those of ya'll not going to WTAC, come to Garage Cafe tonight... will be repping /evolinesaustralia... and picking my my drunk father from the city afterwards to give him a lift home from a work function. That'll be a fun drive home *le sigh*
i would come but im coaching some weird nation (seychelles or mauritious i cant rmemebr) in preparation for a world cup tournament in knox.
im telling you lot this in hope that someone knows anything about it. cos i dont. the owner just asked me to do it.
what? proper footy?
Free market will dictate what the event is worth...if people think it's worth it they'll go and the event will keep running...if not they'll shut up shop as the numbers dwindle over the years.
Which is pretty much what happened to autosalon. Does anyone remember autosalon? Yeah, I bet you do.
I first met Moh at an autosalon probably 4-5 years ago, he was by himself lol
Krysissyu still rocks one of those MASSIVE Autosalon Competitor stickers on his car lol
LOL!
1) Wear dick-tight short shorts
2) Have full sleve tats
3) Grow bush ranger beard
4) Pat your team mates asses at any and every opportunity
5) Do something retarded/illegal off field and receive preferential treatment
6) Repeat
  • Like 1
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
