Picked up the new laptop today...Using it now, internet is running like shit...
Anything that needs to be done to fix that? It's connected to my wifi obviously, was dropping out flat out at the start but I used the troubleshoot and it seems to have fixed the drop out issue...speed is still slow though...Would I need to login to my router and accept this IP or anything like that? Have had to do that with phones etc in the past, but this connected automatically when I set the laptop up...
just plugged it into the router and everything is loading fine.... the signal strength on the wireless was fine though so it can't be that... it's gotta be something to do with it connecting/dropping out like it's not allowed on the network or something....surely this brand new gaming laptop doesn't have a shitter wireless than my 5 year old regular laptop..
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
