At my parents place, signed into the wifi...9mbit/sec downstairs with the router upstairs... Didn't touch any settings... So seems to be the router at my place...
Will buy the stealth bomber lookin ma'fkr and enjoy the speedz
  • Like 1
Didn't your old laptop work with the router though?
Yeah but thats coz it's old as well, so it works well with the old router telstra gave me... It's wireless G...This card can connect but doesn't work at it's potential with an old router, so a new router should fix it...My parents have a wireless-N router here and it's working fine...was working fine at centercom too...
You are sooooo looking for an excuse to justify the new router loo
Telstra want $216 for their AC router, that porno bad boy is $339....Once I've seen something I want, it's very hard for me to buy a lesser product lol
Not including clapped out fords :P
That was a different time... Things have changed :)
Well let's hope that works :)
It should, but I'll confirm with centercom before I buy it... don't see why it wouldnt though, parents router is N and working fine, the gangster one is AC which is what this card is made for so should be sweet...and no one had to have their nose broken, no walls need repairing
Am losing 1.5v between alternator and battery.
Alternator producing 14v+ but battery ain't seeing more than 12.5v
Weird problem. I'm guessing the lead from alternator-fuse-battery must be leaking?
Car's too old. Sell and buy a maserati
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
