lol when I was in NYC with some mates we were walking near Central Park and this absolutely gorgeous girl with a sexy eastern european accent ask us if we wanted to hire bikes for a couple of hours to ride around the park. So of course we were all like "yes ma'aam"...
Nek minit we're in an alley with 4 huge adidas tracksuit wearing mother fùckers straight out of the movie Hostel, getting rusted shïtter bikes out of the back of a van... for $10/hour, with a $30 security deposit that we didn't expect to see again, and a $10/15min overusage fee.... Didn't help that they'd moved the van when we came back an hour and a half later...
Still, point of the story was the girl was hot.
thats a because mohsen move simon.
jesus simon, keep it together. f**k.
  • Like 2
And a cool story it was
Waiting at Royale Burger and HWP are parked up in the alleyway next to the shop waiting aswell. Ignoring calls on the radio and instead checking street signs when people park .
need some more forgiving coilovers.
have heard good things about MCA. can anyone confirm?
or should i just get my teins revalved n shit
http://www.drphil.com/articles/article/731
