old boys buy boat.
ask me to buy into it.
i refuse because all mechanical failures will be my fault.
boat gets taken out second time.
sucks up something in the water.
water pump gets jammed shut.
motor cooks.
they mohsened so hard i might have to change my name.
  • Like 2
Mohsen is learning
Na, now he'll buy it from them at 1/2 price because it doesn't run....
2 years from now he'll try to sell it for 1/4 price after the motor has corroded solid and it'll covered in bomb residue
old boys buy boat.
motor cooks.
fucking lol
and i cant quite explain the feeling i had when we turned the bend near craigiburn, and there it was, the melbourne skyline in all of its glory.
9 hours at 3000rpm with no AC, massive road noise and stiff suspension wasnt fun.
you are such a bitch.
you have street oriented coilovers, operational windows and comfy comfy GTR seats.
looks good, pity about the owner as you say
old boys buy boat.
motor cooks.
LOL!
I'd be more impressed by Ken Block Gymkhanas if there wasn't 10 sets of tyre marks on the road in some sections, 3 in others, 5 in others....
Just makes it painfully obvious that it's not a single run, it's been tried and failed multiple times, then they just cut together the more interesting footage that they've gotten.
This is a bit more impressive, as its actually a single take
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
