Grant what happened to the GTR?
Also who was previous owner of WRX pretty sure seen it at some track days
A curry caused this,
And spent a while waiting for insurance to pull their finger, they want a 'live assessment' which is happening sometime tomorrow, wouldn't hold my breath on that happening.
So far I've worked it out I'm the 5/6th owner.
Bought it off Asian dude, I think the bloke before him is the club member, noticed a mark where wrx club sticker used to be this morning.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
