tyres for steerers.
what do you all rekon? while torching tyres is fun.
i got my hands (practically stole) on a pair of ad08rs to keep the rear planted
So... put some AD08R's on the front... Front grip is more important than rear grip... Unless you wanna understeer and make sweet love to armco
tyres for steerers.
What size?
Im trying to get rid of some Hankook Rs3's
How badly you trying to get rid of them
Depends how much your going to low ball me.
I don't mind getting rid of them, but not desperate. Know what I mean?
Thought about just wrapping them up and keeping them, but that also clogs up my garage
They are also currently on rims so i wont also need to pay to get them off em which is a pain :/
My R1Rs are wearing down but not dead yet so how much I low ball you depends on how much you high ball me
Didn't you have another set too?
I got 2 x brand new ones 265/40/18
and 2 x worn ones 265/40/18. I haven't measured the tread but maybe 60ish %?
Take the driftek rims with it and get the whole lot cheap cheap
wont be tracking it any time soon..
too much shit to pay for .
You really want me to give up my D1Rs for some cheap common wheels?
Will PM you about the tyres. Do you know what year of manufacture they are?
i just had an asian family walk into the store, and everyone had an aussie accent.
when i say aussie accent, i mean, like birds after hes had one too many vb's some pingers, a point of shard and a hoon around in a VN 5litre.
mind blown.
Pretty sure they are 2013 manufacturer. Probably mid?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
