You don't need new anything, you need a fuel system that supports the flow capacity
If your current stuff can do that then you can keep it
New lines and rail are unnecessary, pump and injectors is all that really needs an upgrade assuming your current ones are unfit
well that would be stupid if he has something that will obviously not make it, like 500cc injectors for example
he would just have to pay for tuning twice....
although that WOULD be a fairly Mohsen result
  • Like 1
What injectors / fuel pump / etc are in the car at the moment?
You're not making insane power so don't worry about lines / surge tanks / rails at all.
I would look at estimated power levels and install injectors and fuel pump to suit, before the E85 tune, or you'll be back to Racepace 5 times over the next 2 months and complain about it every step of the way.
exactly.
car has
walbro 255lph pump
stock injectors
stock rail.
wouldnt take any more ignition timing and detonated when more boost was added. so gonn get some cam gears and hopefully solve that problem.
current wish list is z32s, id1000s, cam gears and some brand new coil packs.
car has
walbro 255lph pump
stock injectors
stock rail.
call scotty right f**king now.
Someone did that in the test lol
Object fixation is a bitch
Never look at where you don't want to go lol, at least until you're experienced enough to control the bike independently of your vision
I'll know when I'm there if I don't hit a pole after looking at it
Can't remember what color is what... Then Broadfords colors are different again just to make it worse
From memory white is slow / inexperienced, green is moderate / experienced (2 minutes and above laptimes), red is balls out / below 2 minutes.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
