yea I often play games through 4g on my work laptop while bored in hotel room
I got 85mbps at shepparton one weekend at the deca hotel
edit: you also missed my D1R que
Edited by UNR33L
Thanks peoples. I dont mind the square, mainly because not many cars can pull it off. I would prefer a more sharp square or is it too merican v8?
http://i00.i.aliimg.com/wsphoto/v0/1586797766/2-4-font-b-Inlet-b-font-Rectangle-Shaped-Dual-Outlets-font-b-Exhaust-b-font.jpg
http://solo-performance.com/images/tips/t109-1l/1.jpeg
Struggling to stay awake, Sandown track day really took it out of me. Still need to unpack the car but cbf.
Evo back home with no issues, how's your rex Grant?
Made it to home by nursing it a bit.
Still need to do few things before heading out again. Platts has talk me into converting to sugar cane fuel, I foresee bad things :P
Lawwdd give me strength I am definitely the same right now, it can all wait until tomorrow!
I would have tried to talk you into it, but you never listen anyway. :P
now do a winton day drive up in the morning, race all day and drive home at night.
then I'll listen to you..
Will do, now I know it will take it. Shakedown ran smoothly, glad it was at Sandown as the tow charge would have been cheaper. :P
Evo is a bit of a handful to drive fast, and will only be faster by the next track outing... Coilovers and more boost to come.
You have stock suspension?
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
