they take too long to sync, most only check their time once a day, and when I go through so many time zones it too long.
for travel I use a pebble steel smart watch that syncs real time to my phone.
and phones sync of the local network so I'm always correct
https://getpebble.com/pebble_steel
haha nothing wrong with fashion.
discussion point: if a workplace culture condones the use of designer tie-clips, this may allude to the point that business-attire could be a factor on the judgement of colleauges. (excluding colleagues who deal with external clients etc)
May not be an issue in your space as mentioned but could be in other places.
Have always worn company issued uniforms for both Site & office along so never had the issue.
However where ones uniform is prescribed, the stand-out factor is usually the flashiest watch.
More people teased me about my Tiffany tie clip than admired me for it lol
Helps that I'm good at my job and not a terrible bloke though
  • Like 1
sorry for taking an interest in my car....
ps; ive driven just over 3000kms since i got it in may this year
I've driven 3000kms since last week
You're all missing the main point here, that Ric was told not to dress sexy at work but continues to spit in the face of authority.
And all that dress for the job you want shit just goes to show how shallow your corporate shit holes are...
  • Like 4
at telstra we don't have a set uniform or corporate standard
flexible working
yes but you have to work for telstra...could be worst...teletech...
Slacks, dress shoes and a collar are the only prerequisite at mine
Can have whatever facial hair etc. polo tops etc.
our office is collar and no ripped/offensive clothes.
but when customer facing need to dress well,
that said after getting suits tailored properly, they much more comfortable than anything except tracky pants
The way you present yourself is an extension of your personality.
Chefs are a great example. You never see a scummy motherf**ker working in a fine dining kitchen putting up good food, and you never see a kempt ass motherf**ker working in a shithole on lygon st.
I base part of my hiring on appearance and always will.
If you can't be f**ked dressing well I don't want you in my office/kitchen/wherever representing me
I didn't say anything about dressing like a homeless kunt, but if the fact you don't wear/can't afford a $3000 suit means you don't get a promotion over the sexy Ric looking mother f**ker at your work, who isn't as good at your job as you are, then your corporate world can smoke me.
  • Like 2
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
