Still gotta put the headunit in the excel, been driving with no radio/cd/tape/8trak/record player for probably a year or more now, but cbf taking the dash off
Got to do my excel too, planning to buy a $50 ebay one.
No recollection, but sounds like something I would've said.
Not sure if this has turned into a 'when did you meet des' thing, but if that was about me, again, no recollection of it lol
whoops was meant to say that was mohsen
I also can't remember our first meeting, just remember duck nights which would've been around then sometime
Yeah can't tell the difference. Have always had lifter tick on cold starts but the sound is constant now. Not sure if lifters or something else
Probs still lifters, might have one stuck solid now. Run some lifter free through it and see if some/all of the sound goes away?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
