Still gotta put the headunit in the excel, been driving with no radio/cd/tape/8trak/record player for probably a year or more now, but cbf taking the dash off
Got to do my excel too, planning to buy a $50 ebay one.
No recollection, but sounds like something I would've said.
Not sure if this has turned into a 'when did you meet des' thing, but if that was about me, again, no recollection of it lol
whoops was meant to say that was mohsen
I also can't remember our first meeting, just remember duck nights which would've been around then sometime
Yeah can't tell the difference. Have always had lifter tick on cold starts but the sound is constant now. Not sure if lifters or something else
Probs still lifters, might have one stuck solid now. Run some lifter free through it and see if some/all of the sound goes away?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
